Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-10-2007, 02:37 AM
dessler dessler is offline
Stumped!
I have a 97 1500 5.7lt 4x4. Latley it has been diying on me. every thing shuts of, wheel locks and it just rolls. i come to a stop and have trouble starting it, i give it gas and rev the rpm's untill it stays alive and then take off again, usually with no problem. I took it to a mechanic who replacedthe fuel filter plugs distributor cap and rotor put in some chemical cleaner and charged me way too much. I picked it up and drove it to work with out any problems. When i was leaving work it died and i had trouble starting it. when i got it home i tried to have it die on me again but it worked fine any suggestions? Thank you
Old 05-10-2007, 04:05 PM
maxwedge maxwedge is offline
A990 racer
Re: Stumped!
When it dies and will not start do you have spark and fuel pressure, 1st step in the diagnostics. What do you mean everything shuts off?
Old 05-10-2007, 04:42 PM
2000CAYukon 2000CAYukon is offline
Re: Stumped!
If everything, like gauges, are shutting off, then you need to check both ends of both battery cables for corrosion or a loose connection.
//2000CAYukon
