Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 05-10-2007, 12:13 AM
XTXantiheroXTX XTXantiheroXTX is offline
'97 Sunfire - Brakes & Rotors?
i just recently bought a '97 sunfire and i need to replace the brakes and rotors. ive already bought factory OEM replacements (brake pads and rotors), i just need to know step by step whats involved in installing them. any help is appreciated. thank you
Old 05-13-2007, 07:16 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: '97 Sunfire - Brakes & Rotors?
Fairly simple to do. You'll need a 3/8" Allen wrench to remove the calipers (2 bolts each caliper), and a "C" clamp large enough to compress the piston into the caliper in order to fit the now pads over the rotor when re-installing. Use an old pad as a lever when compressing the piston.
The rotors should simply pull off the spindle once the caliper is removed.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 05-13-2007, 07:56 AM
Scrapper Scrapper is offline
AF Premium User
and get some brake clean to spray of the new rotors
and make sure you use some disk brake quiet or you could have a squel if not..good luck....
scrapper....
Old 07-12-2007, 09:56 AM
Cobraman1024 Cobraman1024 is offline
I didn't use a clamp to compress the piston on my calipers, mine actually had an adjustment screw or something that compressed the piston. its been too long to remember exactly but i know i didn't have to use a clamp.
Old 07-12-2007, 04:08 PM
ChemMan ChemMan is offline
Go to your local auto parts store and buy a chiltons or haynes manual for the car. It is worth it.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 07-16-2007, 02:35 PM
captaink captaink is offline
I second getting the chiltons manual.
Being a newbie myself at trying to do my own car work I found it very helpful.
Plus it makes it easier to ask and understand questions you may ask here.
