Old 05-09-2007, 05:15 AM
flip888 flip888 is offline
Bad Transmission?
I just got a free 1991 honda civic dx auto that wasnt running yesterday. I towed it home and jumped the battery and now the motor runs absolutely perfectly, but the transmission occasionaly makes a loud grinding nois and it slips to where the motor free revs. someone was telling me i just need trans fluid but to me it sounds like something is hella messed up. Now i now nothing about auto transmissions, so i just thought i would ask you guys before i buy another transmission.
Thanks
Also i havnt been able to find anything out about doing a 5speed swap (i searched), but if i could get any info on that i would definently appreciate that also.
Old 05-09-2007, 11:37 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Bad Transmission?
Check the fluid level and if its low add some, use Honda ATF. You may also just try a fluid change. From the slipping it sounds like it could be a bad torque converter. A manual swap isn't that hard. You need a manual tranny, pedal assembly, clutch cable, manual ecu and of course a clutch/ flywheel.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
