Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 05-09-2007, 01:25 AM
Luke 22 Luke 22 is offline
89 Ranger both low beam headlights out.
Lights flashed for a second when turning them on.
Front and rear driving lights work.
All fuses looks good.
Is the fuse in the pull down fuse panel?
high beams work.
pulling the high/ low lever :both should come on but only high beam comes on.
Thank you for any help.
Old 05-09-2007, 07:17 PM
DonSor DonSor is offline
Re: 89 Ranger both low beam headlights out.
Replace both lamps. If either high or low beams or both malfunction, you have to replace to entire bulb.
Old 05-30-2007, 01:26 AM
One light was blown the other looked good but measured as an open. Changed both bulbs the lights know work. Keeping the one that looks good to be a spear to see if it works if one blows again.
Thank you so much
