Old 05-08-2007, 11:51 PM
jgaches jgaches is offline
98 Windstar 3.0
I need help! My brake pedel was going down to the floor so I changed front pads as they were worn. Back shoes were ok. I went to bled front but right front could not get fluid. There is fluid to left front. The ABS and BRAKE lights both are working properly. So I changed the right front caliper and then the brake hose. Still no fluid. I started at the ABS unit and there is fluid to all wheel lines. The right front line has 2 parts. There is fluid to the split and the second line I can blow air through But still no fluid to the right front. Any ideas?
Old 05-09-2007, 11:59 AM
Re: 98 Windstar 3.0
Old 05-09-2007, 04:47 PM
Re: 98 Windstar 3.0
Has anybody had a problem in bleeding the brakes on a 98 windstar? I really appreciate any help you can give me.
Old 05-09-2007, 08:52 PM
wiswind wiswind is offline
Re: 98 Windstar 3.0
You could try one of those hand vaccum pumps....and try pulling the fluid.
I connect mine to the bleeder screw.....pump up some vaccum, and then, using a thin "bleeder" wrench, open the bleeder screw....and pump the vaccum pump to draw the fluid out.
I have a "Mighty-Vac" that has a vaccum gauge on it.
It sounds like you have a LOT of air in there.....and using the vaccum pump should enable you to pump a vaccum....which will pull the fluid down.
Air Compresses (and the opposite....goes to a vaccum), the fluid does NOT compress.....
Just a little air in the system will cause the pedal to go soft....and even to the floor, as you mention.
Once you get the fluid to flow freely (make sure you don't pump the master cylinder dry), pump a fair amound more fluid out......then....with a vaccum pumped up on the pump.....close the bleeder screw.....preventing air from entering back in as you close the screw.
It might take a bit to get all the air out of the system.
I had a bit of air in my brake system.....and the pedal felt firm until I started the engine.....so be super sure about it before you take off down the road.....
I would drive up and down the driveway a bit before going into the street.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-09-2007, 10:15 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 98 Windstar 3.0
[quote=jgaches]I need help! My brake pedel was going down to the floor so I changed front pads as they were worn. Back shoes were ok. I went to bled front but right front could not get fluid. There is fluid to left front. The ABS and BRAKE lights both are working properly. So I changed the right front caliper and then the brake hose. Still no fluid. I started at the ABS unit and there is fluid to all wheel lines. The right front line has 2 parts. There is fluid to the split and the second line I can blow air through But still no fluid to the right front. Any ideas?[/quote
Hello
How many miles on your 98? How long have you owned it? Have you done a brake job before?
I've seen brake bleeders plugged and not allow fluid to come out. Try removing the bleeder all the way and check to see if it's pluged. I've also heard of brake hoses clapsing on the inside and act like a check valve and not allow the calaper to release causing the brakes to drag. I don't know if it could happen the other way.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
