1997 Deville Hard Start when cold
I have a 97 Deville with 100K+ miles. When cold it turns over quite a few times before it starts. When the car is warm it starts right away. I replaced the fuel filter and the problem still persists. Other than this problem the car runs fine and the check engine does not come on during the hard start condition. Any suggentions? Thanks
Re: 1997 Deville Hard Start when cold
How recent was the last tune up, if it's had one?
2000 Cadillac STS 2005 Cadillac Escalade 2008 Triumph Sprint ST 1050 ABS |
Had new plugs about 30K miles ago.
Did you also replace the wires? What brand plugs did you use?
Autolite Platinum plugs were used (single not double platinum). The wires were not changed. Do you think it is an ignition problem rather than a fuel delivery problem?
I would check fuel pressure when cranking also, try a can of Chevron Techron, dirty injectors and carboned up intakes can also cause this.
FWIW YMMV |
Try the fuel pressure regulator also, that's a cheap and fast solution, they cost about $50 and you can put on in 3 minutes, my 98 was doing that and it fixed it immediately, if you have already checked plugs and so forth.
