Old 05-08-2007, 10:18 PM
71nova_lover 71nova_lover is offline
Banned
95 s-10 problems
i got a 95 s-10 ss with the cpi and i cant keep it from busting flywheels tell me whats going on please every time i raise hell with it i bust another one if you know what might be wrong please let me know
Old 05-09-2007, 10:32 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 s-10 problems
Does it talk back to you and let you know what is bad?
We would need a little more info to be able to help.
Std. or auto transmission?
What engine?
What part of flywheel is breaking?
MT
MT
Old 05-09-2007, 10:45 PM
Banned
no it does not talk back to me or i would ask it what was wrong lol
it has auto transmission
4.3 central port injection some may know it as the spider injection
the whole center of the flywheel where the bolts are bust out
now will that help any thanks
Old 05-10-2007, 07:45 AM
BLAZERBOY69 BLAZERBOY69 is offline
Smile Re: 95 s-10 problems
I WOULD SAY CHECK YOUR DRIVE SHAFT. I HAD THE SAME PROBLEM WITH MY 87, AND I HAD TO REPLACE THE ENTIREDRIVE SHAFT CAUSE MINE WAS BENT A LITTLE TOO MUCH. IF YOU CAN, GET IT ON A TREADMILL AND HAVE SOMEBODY ACCELERATE IT AND SEE IF THE DRIVE SHAFT IS BENT. IT COULD ALSO BE THE BEARINGS, AND/OR THE UJOINTS FREEXING UP. LIKE MY GRANPAPPY SAYS, IF YOU JUST FIXED IT RIGHT, AND IT STILL DOES IT, CHECK A LITTLE FURTHER DOWN THE ROAD. ALSO CHEK YOUR HARMONIC BALANCER. MAKE SURE YOU GOT ENOUGH FLUID IN IT.
Old 05-10-2007, 08:51 AM
MT-2500's Avatar
AF - Advisor
First thing use a GM dealer OEM flywheel.
Mach the year of the engine build with the same year flywheel.
Proper torque on flywheel bolts.
Check for excessive crankshaft end play.
Make sure transmission is bolted up good and tight and the dial pins are installed good and transmission dial pin holes are good.
Check for any engine vibration.
If that all checks out the flywheel should stay in there.
Good Luck And.
Let us know how it goes.
MT
MT
