Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-08-2007, 08:48 PM
weathermedic weathermedic is offline
Code P0442 in my 01 Rodeo
Got an ODB code of P0442-Evaporative Emission Control System Leak Detected (small leak)
Could this mean I need to replace my IMG again? Did it around 35k. Have nearly 80k now.
It's been giving me a little trouble starting (cold) in the warmer weather the last few weeks. Takes a bit to turn over and then sputters a bit until it recovers and eventually warms up.
It also seems to be running high on the RPM gauge around the 20-30 mph (2nd-3rd gear-automatic tranny)
Any other ideas?
Jason in NYC
Old 05-08-2007, 10:36 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Code P0442 in my 01 Rodeo
my 1st IMG went at 55k ... the second went at 75k...
so it is possible.
when is the last time you cleaned the egr and egr tube?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-08-2007, 11:43 PM
Cat Fuzz Cat Fuzz is offline
Before you go spending hours and thousands of dollars on this, check your gas cap. Make sure it's on there tight. Might want to just get a new one anyway, then clear the code and see if it comes back. If it does, then continue troubleshooting. The code is probably unrelated to how it's running.
Old 05-09-2007, 03:56 PM
Changed the EGR at 45k. Gas cap is good (new one purchased about 1 yr ago)
Jason in NYC
Old 05-09-2007, 04:38 PM
Isuzu Guy
Did you clean the EGR tube? It exits right behind the throttle body.
-Ryan
Isuzu Moderator
Car Show Tips
