Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-08-2007, 07:24 PM
vzfox vzfox is offline
Question manual transmission fluid type
1983 Camaro Berlinetta V6 2.8L 5spd transmission
I checked with AutoZone on what type of transmission fluid to change my manual tranny fluid with......they told me Automatic Tranny Fluid. I trusted them and drained my old fluid. When doing so, it didnt appear to be auto tranny fluid coming out, but more like some sort of gear oil. I replaced the fluid with auto tranny fluid like they said to do. I have a Haynes manual also and it doesnt say what type of fluid to use.
Did I put the correct manual tranny fluid in it?
thanx.
Old 05-09-2007, 01:31 AM
Morley Morley is offline
Re: manual transmission fluid type
Auto trans fluid isn't the right fluid. It should be 70wt gear oil unless it is a "World Class" T5, which yours isn't if it is the factory original. The WC T5's used auto trans fluid.
Old 05-09-2007, 04:40 PM
I have called quite a few auto parts stores around me, and they have all told me "Dexron II or Dexron III" auto trans fluid. I have also tried doing a search via Google for manual transmission fluid types, and came up with nothing. I still dunno what fluid to use. I need more information.
Old 05-09-2007, 07:36 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
You used the right fluid. Dexron III.
Old 05-10-2007, 01:31 AM
http://www.allfordmustangs.com/Detailed/349.shtml
Dextron is correct for the WC T5's that were used in V8 powered cars. The 4 & 6 cylinder cars didn't get the WC (World CLass) T5's, just plain old T5's.
Old 05-10-2007, 07:19 PM
I called three different transmission shops and they all said the same thing.
Old 05-10-2007, 07:51 PM
thanx.....I feel better knowing I put the right fluid type in it. Just sounds odd, Automatic Tranny fluid in a Manual Tranny......anyways, thanx guys.
Old 05-10-2007, 08:09 PM
I know it seems strange, but i believe what i was told, just because three different trans shops and all the Parts houses all said the same thing about it.
I called coker, fleet, liberty, AZ, "o'reallys", American camaro and firebird, and a few dealerships as well and they all confirmed ATF is to be used. I mentioned the difference in color, they said it might have had some DEX II left over in it, just be sure to get it drained good before you refill it.
EDITED
