Old 05-08-2007, 07:11 PM
ripptide56 ripptide56 is offline
2001 2500HD Hard To start
I have a 2001 2500HD 6.0 that when the truck sits for an hour or so and you try to start it it will just keep cranking,but when you stop and then turn the key to crank it again it starts right up..Any ideas? I was thinking maybe the fuel pressure regulator or the fuel pump.
Old 05-08-2007, 07:38 PM
rjeffery rjeffery is offline
Re: 2001 2500HD Hard To start
You got it, either FPR or fuel pump. I had the same problem on my 02 4.8. I replaced the fuel filter and FPR, but did not fix problem. Replaced pump, and problem fixed.
Check your FPR by running the truck for a while then shutting it down and pulling the vacuum line on the FPR. If fuel runs out it needs to be replaced.
A fuel pressure test should also tell you what the problem is.
Replace the fuel filter if you havn't done so in a while.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 05-10-2007, 11:58 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Another possibility is a plugged fuel filter, happened on a 2001 Suburban 5.3 that I worked on once.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-23-2007, 12:20 AM
Slaglct Slaglct is offline
I had a problem with my truck where sometimes it would crank fine, others it would keep turning and turning and eventually crank. Everything was fine that I could tell. It wasn't a major issue until I was driving 80 down the interstate at night and everything shutdown. After a couple trips to the mechanics it ended up being a faulty crank sensor located back behind the engine, so if your problem persists it could be something to look into.
Old 05-23-2007, 07:57 AM
Was that on the 8.1? That is a common problem on those engines.
Old 05-24-2007, 06:52 AM
wafrederick wafrederick is offline
Banned
Sounds like fuel pump and stay away from aftermarket fuel pumps,they are junk.Airtex and Carter are two to stay away from.Most aftermarket fuel pump's warranties are deneied right away.Go with a GM fuel pump from the dealer.Went through this last month,put 4 fuel pumps in my cousin Steve's 2001 Olds Alero.Three were Carters and the 4th one one is a GM fuel pump.Have not seen it since after puttting in the GM pump.
Old 05-24-2007, 03:11 PM
Yes. It was with the 8.1L, now I have some type of problem with a loose shifter causing the key to not turn.
2001 2500HD 8.1L Allison Tran
Old 05-24-2007, 09:47 PM
Thanks for all the good advice I've been working alot lately and now just getting the time too look into it. I think I will try the FPR first because it's a little cheaper and easier to replace. Thanks!! I'll let you guys know if that works.
Old 05-24-2007, 11:12 PM
Yeah I would try everything before replacing the pump. It is a pain in the ass, and expensive. Do a fuel pressure test on it and post back the results:
You fuel pressure is to low.
Specs on it is 55/62 lbs of pressure
Here is some guide lines of fuel pressure checking.
Hard to start cold.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 55-66 fuel pressure.
Cold start should be 55/62 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Engine running should be 55/62 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
If pressure does not come up with return line pinched or blocked off.
Go to fuel filter and hook a gauge direct to a line at fuel filter.
Pressure should come up to 75 or more and will hold after fuel pump is turned off.
If it leaks down there after fuel pump is turned off it is LEAKING BACK THREW PUMP CHECK VALVE OR PUMP MODULE LINES.
Post back your fuel pressure readings.
(Copied from MT)
Old 05-28-2007, 12:27 AM
Now when I start the truck and it finally starts after having trouble starting it runs rough and it gives the code multiple missfire. I turn it off and restart it, it will start up perfect and run perfect and run fine after that until I let it set for awhile. It doesnt do it everytime but more often than I would like. Also I took it to the dealer and they said I had clogged injectors so I had them do the recomended injector clean, But that did not help.Thanks.
Old 05-28-2007, 12:28 AM
The dealer said they also checked the fuel pressure and it was within spec,But I forgot to ask them what there spec was.
Old 05-28-2007, 01:18 AM
WalrusInc WalrusInc is offline
Whose fuel ya buyin?
Old 05-28-2007, 01:43 AM
Since I work for Valero I also buy their gas. But i'm more inclined to say it is the fuel pump. I'm going to do the fuel pressure check myself
Old 05-28-2007, 06:43 PM
Valero? Wouldn't you be better off running water with starter fluid? Yuck.
Old 05-29-2007, 05:36 AM
I can tell you no nothing about the refining of gasoline.
