Old 10-19-2002, 09:14 PM
La Temperanza La Temperanza is offline
Send a message via AIM to La Temperanza
Putting the "turbo" back in turbodiesel
Well, unless you like full-size pickups, the only diesels on the open market in the USA are Volkswagens. And their TDI engines are pretty unspectacular; 90 hp and 155 lb/ft of torque. There's worse out there, but there's also a lot better.
I'm not yet a real tuner, seeing I don't want to waste good cash on the minivan I'm driving now. Any of you know of some aftermarket magic for a diesel engine that might soup up one of those VWs enough to take on stock Hondas without fear?
Old 10-19-2002, 10:01 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Does this sound like the sort of thing you're looking for?
http://formen.ign.com/news/23047.html
"the bored and stroked TDI beetle now squeals the wheels to the tune of 295 horsepower and 210 lb/ft of torque through a stock block bored from 1.9 to 2.6 liters."
or this?
http://www.bb-automobiltechnik.de/en...beetletdi.html
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 10-20-2002, 08:25 AM
SaabJohan SaabJohan is offline
Two stage turbocharging should be nice... but probably expensive.
Old 10-22-2002, 09:29 PM
911GT2 911GT2 is offline
Wow. They managed to make a TDI more powerful than torquey. Doesn't that kinda defeat the purpose??
Some people deserve to have their vocal chords ripped out. Oh yeah, and American beer is like having sex in a canoe...it's fucking close to water.
Proud member of www.automobileforum.com
Mod -www.autoworldforums.com
Old 10-23-2002, 08:16 AM
um, what purpose are you referring to? It's not like they lowered the torque output.
Old 10-23-2002, 04:14 PM
Oh, i know, but diesels rarely have more power than torque from what i've seen. Could be wrong though, seeing your reaction.
Old 10-23-2002, 05:19 PM
That's really just a matter of the shape of the torque curve and the operating speed range. An engine that reaches peak torque at a fairly low rpm will have high torque relative to power.
For ANY engine, if peak power happens at less than 5252 rpm, peak power in hp will be less than peak torque in ft*lbf. The converse is not necessarily true.
(correct me if I'm wrong on the above, but it sure seems right to me.)
Old 10-23-2002, 05:33 PM
Yep, you're right on that one. Even with a 4000 lb-ft torque peak at 5251 rpm, your hp is 3999.2 hp.
And I see that I may have caused confusion earlier. I wasn't insulting the fact that they got more power than torque, i was just surprised. You usually don't see too many diesels turboed or not get more power than torque. I guess that with a higher CR characteristic with diesels, the engines can't rev too high.
Must've lowered the CR by quite a bit.
Old 10-23-2002, 11:40 PM
Not necessarily. If they messed with the compression ratio at all, it was probably just to keep peak cylinder pressure reasonable with the increased boost.
Old 10-24-2002, 05:08 PM
Yeah, you can't run huge boost with 13:1 compression or higher even.
Old 11-07-2002, 05:14 PM
454Casull 454Casull is offline
I had a question, and it seems like it might get an answer in this thread.
Why can't diesels rev as high as petrol engines?
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 11-07-2002, 09:32 PM
well, maybe not huge, but I've worked on a diesel engine design that ran 55psi boost @ 18:1 compression...
Old 11-07-2002, 09:55 PM
In general, because they're built to run more slowly. There are diesels in the works that will run at 4500-5500rpm, but nothing that I'm aware of that will run much faster than that.
Part of the problem is probably that the peak cylinder pressure in a diesel requires heavy reciprocating components, while high speed operation favors lighter components. The gas force balances the inertia force when the piston is at the top on the compression stroke, but there's no such balance on the exhaust stroke, and BDC acceleration can be just as bad.
Search for HSDI online and see if you come up with anything interesting.
Old 11-08-2002, 06:55 PM
Wow....18 wheeler turbodiesel??
I worked at a moving company for the last 2 summers so i've seen and heard a whole lot of turbodiesels. They run some crazy boost in comparison to high boost DSMs and such.
But you worked for a trucking company at one time didn't you?
Old 11-09-2002, 09:36 AM
At one point I worked for a semi truck OEM. I currently work at a consulting firm that does a great deal of engine design.
The 55psi/18:1 engine was based on a truck engine design, but was not intended to go back to that application.
