Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-08-2007, 07:07 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
Brakes, Ceramic, Metallic or Semi-Metallic?
Sup Guys,
I purchased a new set of crossed drilled rotors and am a little unsure as to which type of brake finish to get Ceramic, Metallic or semi metallic? Which material would be most effective with this type of rotor? Any feedback would be greatly appreciate.
Thanks
99 Eclipse Spyder GS
Old 05-08-2007, 07:11 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: Brakes, Ceramic, Metallic or Semi-Metallic?
i have semi metallic on my dual piston calipers with brembro slotted/drilled rotors, and i stop on a dime! they squeek every now and then when they are hot, and i'm just barely touching the pads to the rotors... but stops like hell! i have axxes pads... for them
Old 05-08-2007, 08:21 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I use ceramic Akebono pads and absolutely love them. Minimal dust, no brake fade, squeeling, or spongyness to the pedal regardless of how hard I brake.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-09-2007, 01:52 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Well if they put ceramic pads on the veyron they probably good enough for the eclipse
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 05-09-2007, 04:56 PM
toicy4ya's Avatar
Thanks for the feedback.
One last question, is it necessary to bleed the brakes after I install the new rotors and brake pads?
If so is it hard? I've never done it before.
Thanks
Old 05-09-2007, 08:15 PM
It's easy to do and I think I had a write up on here from when I replaced mine. I'll see if I can dig it up.
Here you go:
http://www.automotiveforums.com/vbul...d.php?t=397132
1997 Spyder GS-T
5-Speed
Old 05-09-2007, 10:27 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Thanks
It's usually not necessary as long as you don't open the bleeder valves or anything on the brake calipers. I usually just use a C-clamp and depress the brake cylinders. This forces the fluid back into the system and maintains the integrity of the system.(By that I mean not allowing air into the lines) So in short if you use that method no bleeding is needed.
Also Ceramic brake pads ftw.
1991 GSX 2.3 Stroker
Old 05-10-2007, 11:45 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ceramics need to get warmed up[and therefore have a much higher operational temp range, hence racing] before you are at optimal braking potential.
for most everyday driving [and even a litttle stoplight fun] you just want the brakes with the least dust.
or you could go all out and get some
Porterfield Carbon/Kevlar Brake Pads
sweeeeet...
Old 05-11-2007, 08:26 PM
toicy4ya's Avatar
Thank for your feedback guys, you all have been a great help.
I finally installed the crossed drilled rotors and opted for monroe ceramic pads. I took the time to paint the calipers and after getting it done I have to say it looks pretty damn good. However I do have one problem, the brakes on the driver side squeek when im coming to a slow stop. I made sure to add grease between the shims and the brake pad and tighten all the bolts pretty tight, I dont know what it could be, Any ideas?
Thanks again.
Old 05-12-2007, 07:57 PM
defiancy's Avatar
Thanks again.
Did you break the brakes in?
By this I mean making a series of hard stops at varying speeds.
I know there is a write up somewhere on this.
Edit for clarity.
Old 05-12-2007, 08:11 PM
get up to high RPM in 2nd, hard break to stop, repeat 3 or 4 times. if you see smoke stop, but it should only take like 3 times.
Old 05-13-2007, 12:13 PM
defiancy's Avatar
Yeah I thought there was more to it, maybe I'm thinking of something else. What you described is normally what I do. I just thought there was something a little more indepth that I had seen.
