Old 05-08-2007, 02:18 PM
Greg5150 Greg5150 is offline
Crankshaft Position Sensor 1997 PA
I am going to replace the Crankshaft Position sensor on my 1997 Park Ave. My question for the board is regading installation of the new sensor - Is the new sensor simply bolted in place - or is there some type of alignment needed? I also understand the balancer has to be removed. Any comments on this are appreciated - thanks
Old 05-08-2007, 06:26 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Crankshaft Position Sensor 1997 PA
Click Here & Here for more info.
Old 05-10-2007, 12:08 AM
Do you know if the balancer is a press fit on the crankshaft like an older small block chevy or does it slide off easily after the bolt is removed? thanks
Old 05-10-2007, 11:46 AM
HotZ28's Avatar
AF Moderator Elite
Yes, it is a press fit and you will need a puller simlar to one shown in the link: Click Here
BTW, it helps to have a harmonic balancer installer, when you put it back on!
