Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-08-2007, 12:39 PM
radrobbie radrobbie is offline
No Electrical
I parked my 93 3.2l 4X4 rodeo on Sunday afternoon at 2:00. After shutting down the inside fan continued to blow after turning the key off. At 4:30 I went to start it and had no electrical at all. No starter, no accesory, no dome light. I tested the battery, it was good. I cleaned the terminals (they weren't dirty anyway), and and the cable/terminal connection. Still nothing. Where do I go from here?
Old 05-08-2007, 12:44 PM
wing_i wing_i is offline
Banned
Re: No Electrical
Looks like a shortcut. Maybe if you try with a different battery.
Old 05-08-2007, 02:23 PM
Ramblin Fever Ramblin Fever is offline
Re: No Electrical
Are you referring to the radiator fan, or the little one in front of the condensor?
The condensor fan continues to run on mine after shut off as well, if the weather's really hot, it's done it for years.
Have you checked the volt output on your alternator?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-09-2007, 09:11 AM
Re: No Electrical
The fan inside is the one that kept blowing, not the radiator or condensor fan. Also the car wouldn't take a boost either.
Old 05-09-2007, 11:55 AM
Re: No Electrical
further research showed the 60a main fuse blown. I replaced it and it blew immediately.
Old 05-09-2007, 01:48 PM
Andie_J Andie_J is offline
Re: No Electrical
Sounds like you have a major short. The way ive seen it done is remove all the fuses and replace the 60amp main. Then add the fuses back till it burns out. At least then you will know in what circuit you have to look for the short. Andie
P.S. I once saw some guys just jump a fuse with a piece of wire and stand around looking for the smoke or fire. Dont try to find it that way!!!!!
O4 Rodeo, 3.2, Auto, OME's 912's, Kangaroo Chaser
05 Saab, (My two BABIES)
Assorited Pickups for the ranch
Old 05-14-2007, 08:47 AM
Re: No Electrical
Thanks Andie;
I used the removing all fuses technique (not the search for fire), and finally figured out it was the alternator..
problem solved.
Old 05-14-2007, 08:27 PM
surferfletch surferfletch is offline
Re: No Electrical
Thanks for posting the solution!
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
