Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-08-2007, 12:08 PM
Rick_Utke Rick_Utke is offline
Hey its me again..
OK so I posted earlier about my tranni not shifting and the car overheating.. well there were actually two problems.. first, the tranni line was loose so I just tightened the o-rings and then there was a small hole in the radiator so I just put some stop-leak in it and it worked.. but now here lately the car is wanting to shut off, almost like its not getting gas, because it will start acting like its dying and then I give it gas and its fine, it seems that once the car has been drving for awhile its fine but for the first few minutes it keeps wanting to die, So i don't know whats going on, there is an exhaust problem, it needs a whole new exhaust system.. but could that be the problem? I dont know any help is welcome.. maybe one day with your help I can learn enough to help other people lol. Just to refresh your memories its an 89' Buick Century with a V6 3.3 L engine.
Old 05-11-2007, 01:27 PM
doberman_52's Avatar
doberman_52 doberman_52 is offline
Send a message via MSN to doberman_52
Re: Hey its me again..
Whats wrong with your exhaust system? That usually wouldnt do much unless your back pressure is to low but that would be it. when was the last time the fuel filter was changed? that doesnt sould like it but its a start, you could chech the fuel pressure, im not sure what the normal pressure is, check the resistance of the injectors, should be round 12 ohms or so, check the fuel pump and maybe the fuel pressur regulator, see if you have any stored codes and go from there, thats what I would do.
1994 Honda Civic - D15B7 W/5 spd
2000 Olds Intrigue - 3.5
Cory
