i have a 88 crx and i wanna change the tranny fluid.what kind of tranny fluid should i use and how much quart should i put in??
Re: tranny fluid
Honda Manual Tranny fluid (honda/acura dealership), Gm Synchromesh, I LOVE this stuff (GM stealership), or any 10w-30 motor oil.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
Re: tranny fluid
1989 Civic STD - sold 1991 CRX Si - current Free Service Manuals: http://hondatech.info/ |
Re: tranny fluid
I haven't used either one of those, I just stick with Castrol GTX, and I haven't had a problem out of it yet. I think its like 1 1/2 quarts....don't quote me on it because I don't remember exactly because its been a while since I filled it up, but if you buy 2 quarts, that will get it for you.
Tony 91 Civic Sedan DX - Stock 287k Miles |
Re: tranny fluid
I always use non syntehtic 10-30. Honda MTF wasnt around when our cars were made so I see no point in using it.
2 quarts will be enough, just fill it until it starts to dribble out the fill hole.
Saturn Stealership Technician #331 |
Re: tranny fluid
i use to use royal purple synchro till i discovered pennzoil-syncromesh which is the exact same product as GM but a few bucks cheaper and can be bought at ur local parts store..but then found BG synchroshift II and favored it most..i know some of u think im retarded but i have always been super anal about fluid changes like every mth or 2..its the heart of ur car! and well royal purple with lucas oil stab for the motor!
Re: tranny fluid
Re: tranny fluid
Oil changes should happen that frequently, but the tranny doesn't need it that often. I still check mine every so often to see if its still good and tranny fluid last quite awhile. I think the tranny recommendation is like 6 months or something, don't quote me on that either...I just change it when it needs it, no sense in wasting oil when its still perfectly fine.
Re: tranny fluid
is he refering transmission fluid for an auto or gear oil for a manual?
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
Re: tranny fluid
Manual trans fluid should be changed about every 10,000 miles.
