Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-07-2007, 10:48 PM
fastford172 fastford172 is offline
92 LX 2.3 engine vibration
The car has a bad engine vibration from idle to about 2000 rpm's after that it runs smooth.It does the same thing while sitting in park or driving it down the road,it feels as if it has a bad harmonic balancer or wrong flywheel type vibration but the balancer looks fine and it looks like the transmission has never been changed,is it possible that it could be a broken crankshaft? the engine is a 2.3 automatic.
Old 05-11-2007, 10:47 PM
chronomafia chronomafia is offline
Re: 92 LX 2.3 engine vibration
If you had a broken crankshaft, your engine would quite possibly not run. I \'d run with the simple problems first. You may have a broken vacuum line or perhaps your injectors are dirty. They have a high side and low side and the low side may be dirty. So do some problem elimination and go from there.
Old 05-14-2007, 01:19 AM
Ok thanks I will give that a try.The reason I mentioned the crankshaft was because a friend of mine had a 86 mustang gt that had a broken crankshaft and it would still run.
Old 05-31-2007, 09:14 PM
reekor reekor is offline
I would bet on a bad fan clutch.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-28-2007, 12:05 AM
bugman742002 bugman742002 is offline
check yor mototr mounts. the delivery trucks i drive at work have the same problem ant the have a broken motor mount. the easiest way to check them is to open the hood stand off to the sie of the car and have someone put it in gear and power brake it. watch the drives side mount. if it moves and you can see a big gap open up in it it's bad
