Old 05-07-2007, 10:36 PM
arodg25's Avatar
arodg25 arodg25 is offline
valve spring replacement
Does the head have to be off to replace valve springs?
Old 05-07-2007, 10:50 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: valve spring replacement
No, the valve cover does, but if you drop a valve into the cylinder then your pretty screwed as far as getting it back into the head. Id suggest doing each set with the piston at TDC to try to remedy that.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-08-2007, 09:50 PM
arodg25's Avatar
nice, thanks.
