Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-07-2007, 02:28 PM
eagleesi1953 eagleesi1953 is offline
Wobble in steering
I replaced the lateral ball joint for the second time once free by the dealer because of a recall and the second time because it was making a loud grinding noise. 97 Eagle Talon ESI and now at 70+ miles per hour I get a small amount of steering wheel wobble. Should I have it aligned or is the stabalizer rubber bushings loose. How can I tell? Has anyone else had a similiar problem.
Bearings are fine no play.
Thanks for your help.
Old 05-07-2007, 02:36 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: Wobble in steering
are your tires aligned/balanced?
Old 05-07-2007, 05:40 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
That would be my suggestion also. It's also possible you have a slightly dented rim. Might want to have the rim rotated to the back and see if it still wobbles in the front.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-07-2007, 09:08 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
This is what I was going to say
1991 GSX 2.3 Stroker
Old 05-07-2007, 11:53 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Balance the tires and your problem will go away.
95 Talon TSI AWD
97 Eclipse GST
Old 05-08-2007, 12:00 PM
solar-eclipse solar-eclipse is offline
ditto
New out the box
1996 eagle talon tsi awd 78 MILES.... ON THE BODY!!
redemtion is a must.
Rip; 2005 subaru wrx sti.
Finally up on my feet, and working on 2 cars.
Old 05-08-2007, 12:17 PM
Originally Posted by solar-eclipse
ditto
In case you didn't read the rules.
95 Talon TSI AWD
97 Eclipse GST
