| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
clutch
i had my car inspected and they said that i needed a new clutch (hard to get into gear..have to spam the clutch to get it into gear) i dont know too much about clutches but i see clutch 'Kits' for sale with a pressure plate , street disc, throw out bearing and aligment tool. but what is a flywheel? do i need that also? im confused as hell, sorry im a car noob lol
** i have a 95 eagle talon awd tsi with a 92 head and tranny..would i need a 92 or 95 clutch kit? |
Re: clutch
No you do not need a new flywheel unless your has teeth missing or if you desire a lighter one for quicker revs.
-Brian
Re: clutch
Yea you actually do need a new flywheel. The flywheel wears just like everything else. Some people choose to resurface them but if you have hot spots on it from the clutch slipping you must replace it. If you choose not to replace it then dont get pissed when your new clutch starts slipping soon.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: clutch
Re: clutch
Sounds like you have problems with your hydrolic system. You have to be sucking in air from somewere. A worn clutch would slip not make it hard to change gears. Also the flywheel would be determined by the motor you have. You should have a 7 bolt so get a 7 bolt flywheel.
Re: clutch
Yeah if it got better when you bled the system and then got worse again I think it would be either your slave or master cylinder. Just cause they have fluid doesnt mean they are good....Check they slave by pulling back the little boot around the pin and see if there is any fluid in there....Usually if the master is bad it will be leaking fluid down by the clutch pedal.
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
Re: clutch
I agree with silvr about the flywheel. If your car has high mileage, you can try to have it resurfaced, but you are better off getting one with the clutch kit. If you do have it surfaced, make sure they get the step height right. It needs to be matched to the clutch, not the factory specs which is what every machine shop wants to use.
Oh, and check out the master and slave before you go spending money on the clutch kit. I ended up having to replace them both last year on the Spyder.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
