Old 05-06-2007, 11:38 PM
Team PHATBOYZ's Avatar
Team PHATBOYZ Team PHATBOYZ is offline
Send a message via ICQ to Team PHATBOYZ Send a message via AIM to Team PHATBOYZ Send a message via Yahoo to Team PHATBOYZ
Help! Wire Problem I Think!!
Hey guys! If anyone can help me that would be VERY nice. Well i'll try my best to explain it. OK first my starter went out on me so i changed it and now my car wont start. I tested the starter and it PASS. I also recharged my batt. in case although it was low. But the thing is that my BATT has been moved to the trunk so i have to run a long batt. wire to the back trunk. But everything seems to be hooked up good. When i try to start it and turn the key to the last click. My HARZARDs(but very dim) come on and then i have like no power to anything. LIKE if i turn on my headlights then the hazards appear and headlights dont work. MOTOR donnt even CRANK. ANYBODY WHO KNOWS THIS PROBLEM. HELP ME THANKS!!!!! PLZZZZZZZZZZZZZZZZZ
4TH GEN CIVICS ROCK
Old 05-07-2007, 01:46 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Help! Wire Problem I Think!!
Start by checking your grounds, sand them a little and but some vaseline on em and retighten. Your dash wiring sounds like its mixed up with your hazards coming on and all, maybe the wires got melted together?
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 05-07-2007, 12:17 PM
YEa but when i push start it, everything seems to be working rite again. I could signal and everything but when i turn it off and try to start it again it wont start. I try to crank it a few times and then boom the same thing happends again. It takes a few trys to get it messed up again. LIke the wire problem and stuff.
4TH GEN CIVICS ROCK
Old 05-07-2007, 05:22 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
i think u got a ground issue..the best place to ground ur battery IMO would be to the rear strut bolt with a big O ring connector..make sure u sand down to the frame past the paint around that area..also sand down the bolt for the strut so u get a good frame/suspension ground.
Old 05-07-2007, 07:02 PM
Wow Yea That Was The Problem? Cool Guys Thanks. Im Mean It Thanks!!!!!!!!!!!!!!!im Saved Now
4TH GEN CIVICS ROCK
