Old 05-06-2007, 11:24 PM
heavyredchevy's Avatar
heavyredchevy heavyredchevy is offline
O2 sensor question.
Does it matter if I move the O2 sensor downstream to right before the cat when it came stock on the driver side manifold? It shouldn’t right? If anything it should be better because it’s now reading both banks. But ever since I did this just after I bought the truck I have this random hesitation. It only does it when it’s warm which leads me to believe that it’s the O2 sensor. I have replaced or checked all other sensors. I have also checked the EGR sys.
89 Chevy K1500, Extended Cab, Long Bed, 5.7L, 700r4 tranny, 10 bolt rear
Things Done- Flowtech Headers, Heartthrob Deep Tone Dual Exhaust, Airaid TBI Spacer, K&N Intake, 3" Performance Accessories Body Lift, 285 75 R16 Pro Comp A/T Tires, 16" Americain Racing Outlaw 2 Rims, Fabricated Bumper Replacement.
Old 05-07-2007, 04:36 PM
FearlessFoe FearlessFoe is offline
Send a message via AIM to FearlessFoe
Re: O2 sensor question.
yeah.. the headers really dont heat up enough to get the one wire o2 sensors workin.. so if you havent already, upgrade to a three wire sensor.. also, the further back, the better the sensor will read. There are exhaust pulses which smooth out as they travel down the pipe. Usually right before the cat is the best place for the sensor. HTH
Old 05-09-2007, 12:40 AM
ktisdale_2 ktisdale_2 is offline
Where can you find a really good aftermarket 3 wire O2 sensor. I have a '93 with a 350. Thanks again guys!
Keep 'em spinnin,
HiSpeed
'93 GMC Sierra Xtended Cab
350 ci crate engine., 2" Swirl Torque carb spacer, K&N Cold Air Intake, Hedman Headers, Underdrive Pulleys, No-cat 3" true dual exhaust, Dual DeltaFlow 40 Series Flowmaster Mufflers, B&M Shift Plus Kit, SuperChip, Dual 12" Memphis M-Class subs in Custom under-seat downfiring box, '98 Chevy All Chrome grille w/ Billet Bowtie, Clear corners, Rhino Spray-in bedliner.
'97 Grand Am 2. something.
All stock, gas saver....
Old 05-10-2007, 08:00 PM
aftermarket=bad.
go to rockauto.com and order AFS74 (ACDelco 3 wire oxygen sensor) $45
Also, to make a nice setup.. you can order 85393 (Dorman 3 wire weatherpack) $6
I just finished with this setup.. not a single problem.. seems to have increased my mileage about 2-3? mpg
Old 05-11-2007, 12:36 AM
I couldnt find the 3 wire kit there.
Old 05-11-2007, 11:07 PM
Its not a kit.. just a weatherpack connector and a oxygen sensor.. you have to wire it in yourself
my truck just went from 15.5 mpg to a little above 18 after changing just the oxygen sensor so i cant complain
Old 05-12-2007, 10:27 AM
Bob B Bob B is offline
Fearless said:
My truck just went from 15.5 mpg to a little above 18 after changing just the oxygen sensor so i cant complain[/quote]
Hi, What was the original reason you replaced the sensor?
Was it giving errors?
Bob B
Old 05-12-2007, 10:29 AM
Also what year/model/engine truck?
Bob B
Old 05-12-2007, 10:32 AM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
I have the one wire o2 sensor, but want (need) to install the three wire. What wire would go to what. I'm guessing, but does:
1 go to the existing o2 wire
1 go to switched power
1 go to ground
Terminals are usually identified with A. B, C, etc.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 05-12-2007, 11:59 AM
Yes, please specify how you did this.
That sounds about right 68pontiac.
Old 05-13-2007, 07:21 PM
I found a link which ID's the wires for pretty much any O2 sensor made:
http://home.earthlink.net/~jcgebhart/o2sens.html
I found the above link at the following site which seems to have some usefull info for anyone wanting to convert their carbureted vehicle over to TBI:
http://home.earthlink.net/~jcgebhart/msindex.html
Old 05-14-2007, 08:23 PM
Does anyone have ideas on which wire would be easily accessible to splice into for power to the heater on the o2 sensor?
