Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-06-2007, 10:03 PM
rod2004 rod2004 is offline
ATF filler plug for AISIN Trans?
anybody knows if there is a filler plug for this Trans?
I have a dipstick tube but just wondering.
2004 rodeo 3.2L 2WD
AISIN AT
http://www.isuzufaq.com/
http://forum.planetisuzoo.com/
http://isuzuforums.com/
Old 05-06-2007, 10:05 PM
Cat Fuzz Cat Fuzz is offline
Re: ATF filler plug for AISIN Trans?
Fill it through the tube.
Old 05-06-2007, 11:15 PM
Ramblin Fever Ramblin Fever is offline
Yes, you have the sweet tranny with the sweet set-up - fill through the dipstick tube. TRUST ME, be very thankful that you DON'T have to use a fill-plug!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-06-2007, 11:26 PM
I think with the filler plug, you can not overfill since it spills out.
with the dipstick if you're not careful, you can overfill.
2004 rodeo 3.2L 2WD
AISIN AT
Old 05-07-2007, 10:58 AM
Andie_J Andie_J is offline
If you just drained it, it will take about 5 qts. for Dextron III, and if you took the pan off it will hold really close to 6 qts more. Andie
O4 Rodeo, 3.2, Auto, OME's 912's, Kangaroo Chaser
05 Saab, (My two BABIES)
Assorited Pickups for the ranch
Old 05-08-2007, 12:29 AM
Actually I just did a drain and refill last weekend. It only came out about 3.6 qt. I poured the old fluid in a milk jug and measure it.
5 qts seems a little too much. Maybe we have a different trans then.
btw, why does it hold more if you take the pan off ?
and don't you have to buy a new gasket and everything else if you take the pan off ?
2004 rodeo 3.2L 2WD
AISIN AT
Old 05-08-2007, 12:44 AM
got a question for you Andie since you have a rodeo 04.
is your oil drain plug a 22mm or a 17mm hex bolt?
mine is a 22mm and even the dealer says it should be a 17mm hex.
2004 rodeo 3.2L 2WD
AISIN AT
Old 05-08-2007, 03:53 PM
If yours is not a 4wheel Drive they could be different, they are different types of the Aisin Transmissions, (Jerry Lemon, who probably knows more about Isuzus than anyone in North America, and a sweety too) said there were 4 types, 2 for the 3.2 lt, one for 2 wheel and one for 4 wheel. And the same for the 3.5lt.
When u drop the pan u will have to replace the gasket materail they have on it now, either a formed gasket or gasket making stuff will work. I just prefer real gaskets. Easier to get off the next time.
My drain plug is 14mm, and heres a pic to explain why it all wont drain
The transfer case had about a 23mm or so drain and fill plugs.
but nothing like that on the transmission. If anyone can tell me about this transfer case I sure would be appricative. Andie
Old 05-08-2007, 10:43 PM
yep my atf pan is like that too. it did drained but only about 3.6 or 3.75 qts, almost filled a milk jug. but that's it.
I drained and refilled twice to get about 65% of new fluid in there.
I think next time I will do it thru the oil cooler line.
I have a 2-wd drive so no transfer case for me.
Andie, what is your engine oil drain plug size? 22 mm right?
2004 rodeo 3.2L 2WD
AISIN AT
