Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 05-06-2007, 10:14 PM
70Flux 70Flux is offline
Hi! Help! z32 hesitation
My 91 Zed has been running piss poor lately. Feels like its choking and hesitating the worst in the 3-4 rpm range. Couple of issues I know of, but what could it be? Compression test show one cylinder running a little low (%68)? Exhaust leak around the cats? Once it gets above 4,5 rpm its runs a little better, but still rough. Feels the worst when maintaining a set speed. It is a 5spd N/A if that helps. Anyone got any clue about what it could be?
Old 05-06-2007, 10:24 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Hi! Help! z32 hesitation
have you ran the ecu diagnostic on it?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 05-06-2007, 10:30 PM
No. I did try to get advanced to run one the other night while I was there, but its past their age limit. Just trying get an idea of what it could be before taking it somewhere. Check Eng light not on either, though I know that doesnt mean its not throwing any codes.
Old 05-06-2007, 10:35 PM
DeleriousZ's Avatar
it's not that difficult to run them yourself, especially if you've got a factory service manual
Old 05-06-2007, 11:01 PM
I guess, but I dont have the equipment. Ive seen software for laptops, but I dont have the cables. Just thinking someone might have had similar problem or an idea if it could be compression or the cats. I read one post of someone having the cats being leaked on by the exhaust (and I have a leak there) causing somewhat similar symptoms. I know its not a science, just looking for some more clues so I can work on it myself. Indeed thanks for the reply and any additional info.
Old 05-07-2007, 02:14 AM
DeleriousZ's Avatar
what do you mean the equipment? you need a small flathead screwdriver, and whatever to pull the interior panel off...
Old 05-07-2007, 11:32 PM
I thought you were refering to a engine diagnostic where you plug in the tool to read thrown codes. I will give the ecu diagnostic a try and post the codes. Thanks!
Old 05-08-2007, 06:24 PM
Hodo Hodo is offline
He is refering to the diagnostic..... Nissan was nice enough to make this possible with or without a computer scan tool. All you need is a flat head screwdriver and a flashlight helps. You can look at the FSM (factory Service Manual) On 300ZX.org. Odds are your probly looking at best case, bad plugs, or worst case blown headgasket.
Finaly got pics of my car....... after I washed it of course.
