Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 05-06-2007, 10:03 PM
matts89zturbo matts89zturbo is offline
computer problem in 89 300z turbo
hey everyone.. i just bought a 89 turbo z w/ 65k miles. new paint,,good interior. well,,someone just put a clucth in befor i bought the car and now the car doesnt start..someone said the the car needs a computer.i am a teck for lexus but never worked on nissan. can anyone give me a start to figure this thing out..she makes no effort to turn over but the battery is new.is this a problem for anyone???and if so,,i need help to get this thing on the road.
Old 05-06-2007, 10:23 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: computer problem in 89 300z turbo
well first of all you should download the FSM for it...
http://www.phatg20.net/modules.php?n...ownload&cid=67
secondly, have you checked to see if the ecu is operational? you can do this by pulling it off of the pass. kickpanel, turning the ignition key to 'on' and turning the selector screw on the ecu fully clockwise... if you see led's blinking then the ecu should be working... after warming the car up, do this again, and wait for the led's to flash 3 times (mode 3) then turn the screw fully counterclockwise... after this wait for the codes to roll.. the red led= a value of 10, eg. 3 flashes =30, then followed by the green led flashes which equal a value of 1...
if you get a code '31' then the ecu is cooked... the rest of the codes and a better description of the diagnostic procedure is in the 'EFEC' section...
any further questions i'd be happy to answer
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
