Go Back   Automotive Forums Car Chat > Cars in General
Old 05-06-2007, 07:43 PM
roll2daspot roll2daspot is offline
How bad is it?
Ok so I drive a 2003 grand am, and latly ive been shifting my car through the 1,2,3 gears like its a standard just cause its more fun but im wondering if that is gonna hurt my car at all?
Old 05-07-2007, 09:06 AM
G-man422's Avatar
G-man422 G-man422 is offline
Re: How bad is it?
Its a little harder on the transmission if you let your engine get up to higher RPM's before shifting.
Old 06-13-2007, 03:09 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: How bad is it?
Unless you need to hold it in a lower gear to eliminate the downshift time or if you're right where it shifts and it's shifting back and forth constantly, just leave it in drive or overdrive. The computer knows exactly where to shift for maximum fuel economy. Never downshift to slow down with an automatic, it will shorten the life considerably... and replacing the clutches and bands in an automatic is much more costly than replacing the clutch in a manual.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-29-2007, 02:44 PM
Steez Steez is offline
Re: How bad is it?
the only thing we do is drop it into first for burnouts..
