Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-06-2007, 06:29 PM
Nick Dubya Nick Dubya is offline
Send a message via AIM to Nick Dubya
RS battery meter
So, i had my alternator checked and battery checked and wiring checked and its all good
but for some reason when i come to a red light and idle for a long period of time (in gear), my battery meter fluctuates to the 13v line and then dies shortly after if i dont put it in neutral and keep it above 1000RPM.
my friend just helped almost the fix the problem because i had a vaccum hose leak, and there was a (supposed) vaccum hose that came off the throttle body that was just sitting there, so he just plugged it up.
it happens left often now, but the problem still persists
=Dubya
Old 05-07-2007, 08:51 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: RS battery meter
Belt tension.
Old 05-09-2007, 04:51 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
or slipping belt.. or something on the ACC line holding up the belt...? (i think my p.s does that.)
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 05-10-2007, 02:39 PM
i suppose that could be a possibility. i talked to my friend about how i noticed that the oil pressure would drop to the white line before the redline when the car starts to have its trouble
he suggested using a thicker oil and checking the oil sending unit and maybe the MAP sensor for the vaccum problem
Old 05-13-2007, 12:01 AM
droptop94 droptop94 is offline
Do you have stock pullys?
Or have you changed them?
Old 05-14-2007, 12:04 AM
they are the stock pulleys
Old 05-14-2007, 10:29 PM
if you already had the charging system checked out and you have stock pullys then it does not sound like a charging problem.
sounds like you'r friend was on the right track with the vacume leak.
you may have other vacume lines that have leaks.
Or you may need a tune up.
Old 05-15-2007, 08:39 AM
wrightz28's Avatar
keep it simple, a alternator is a belt driven accesory, if it is not being driven properly, it will not function properly. Check for the obvious first.
Old 05-15-2007, 06:04 PM
i have had the alternator checked multiple times over the last few months, and it's still good
Old 05-16-2007, 08:29 AM
wrightz28's Avatar
The alternatro itself can be absolutely perfect, but it will not function properly on the car if the belt and tension is not proper.
What year is the car also?
Old 05-16-2007, 03:10 PM
thats true, i'll get the tension tested
it's a 1989 RS, TBI
