Old 05-06-2007, 06:16 PM
kennydlate kennydlate is offline
shifting issues...
I have a 99 1500 z71....some may remember my water damage issues from b4...New one now...Truck will fire up like it is brand new put it in gear and it will not shift into second gear. If I bring the rpms up then let off the gas it will shift hard into second. It almost feels like I am in 4x4 low...but only the rear wheels will spin if I give it juice...I have the electronic 4x4 selector but no lights are lite up and it will not shift from 2 4 or 4 low..any information would be great..the truck goes into the body shop this friday to get a new look I would like to have it running right by then..thank you in advance.
Kenny
Old 05-06-2007, 07:02 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: shifting issues...
Take a laxative.
Ohhh, wait, you said shiFting issues. My mistake
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-08-2007, 08:12 PM
lol yeah siFting
anyone? or do I have to go to the stealership?
Old 05-09-2007, 12:21 AM
2000CAYukon 2000CAYukon is offline
The PCM controls the shifting on a 4L60E. Inputs are throttle position, RPM and vehicle speed. If some of these inputs are wrong, the tranny may not shift right.
You best bet is to have it scanned with a tranny capable scanner while the problem is happening. This will help determine if the issue is shift solenoid, shift valve or mechanical issue. It will also tell you if any codes are currently stored for the tranny.
//2000CAYukon
Old 05-12-2007, 11:47 PM
thanks...Someone also told me that if my Transfercase control module went bad it wouldnt send a signal to the pcm to let it know what drive you were in! Does anyone know if that is true at all?..I am gong to hook up the tech II sometime this week to see what is going on there..no service engine light is on though. Dont know if that matters at all.
