Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-06-2007, 06:02 PM
johnebarrett johnebarrett is offline
2003 crown vic headlight problem
my headlights will switch off and later turn back on. I hear a click when they go off, i'm thinking its a relay, but i'm not sure where it's located. Any ideas?
Old 05-08-2007, 09:10 PM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Re: 2003 crown vic headlight problem
Sounds like a short in your headlight circuit. The headlight switch has a built-in circuit breaker which is most likely the click you are hearing. Start at the headlights and work your way back to the switch. Wiggle wires and look for loose connections (power & grounds). Check for pinched or rubbing points, or screws that could penetrate the wiring harness, also look closely at any place the harness trouches metal. Good Luck!
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Old 05-10-2007, 06:22 PM
ratm4705 ratm4705 is offline
My car did the same thing it turned out being the lighting control module.
Old 05-10-2007, 11:56 PM
03cvpi 03cvpi is offline
Does this have the standard output headlamp bulbs. If so I would check the wiring harness to the lights from the lights to the main poer box by the battery and back to the LCM. If all connections are good and the grounds, it is most likely the LCM module. It would be good idea to ohm the light switch also, I have seen a few of them go bad, usually wiggling the switch will cause the lights to flicker on/off. If you have something like sylvania ultras, there may be to high of an amp load for an older LCM, You maybe able to cheat and run an aux lighting relay and pull light power off the battery. This requires a bit of electrical know how and is not for inexpierienced.
Old 05-11-2007, 07:16 AM
fleettech fleettech is offline
We have had a bunch of 03's with interment lighting and wiper problems we have traced it to an improperly routed wiring harness from the distribution box under the right front near the front bumper support rod. the harness will rub the rod and will short out causing it to short out
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
