Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-06-2007, 03:42 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Clutch?
Any ideas on a clutch and flywheel kit for a 98 GSX with a 16G EvoIII intercooled turbo system? Im looking for a reliable clutch that will be able to put the power down and shift smooth and quick..... any suggestions?
Old 05-06-2007, 03:49 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Clutch?
Please search as this has been covered many, many times. There are TONS of aftermarket clutches that are great for our cars, it's just up to you to find the "one" you want.
95 Talon TSI AWD
97 Eclipse GST
Old 05-06-2007, 04:55 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Clutch?
It all depends on your goals man....Personally I would go with either the ACT 2600 or the Centerforce Dual Friction clutch....This page descirbes the differances a bit.
http://www.roadraceengineering.com/ecldrivetrain.htm
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 05-07-2007, 06:55 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Clutch?
If you wait a week or so, I'll be able to review the HyperDrive C2 clutch, PP and Flywheel. The Spyder is at the shop right now for the install. Hopefully they get it done today, since I have to go out of town for the rest of the week on business.
It uses a different leverage system allowing pressure to be transferred somewhere other than the thrust bearing. There also isn't any break-in period, which is nice.
Hopefully by next week I'll be able to get something up.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-07-2007, 09:25 AM
solar-eclipse solar-eclipse is offline
Re: Clutch?
act stage two clutch... works like a charm!
New out the box
1996 eagle talon tsi awd 78 MILES.... ON THE BODY!!
redemtion is a must.
Rip; 2005 subaru wrx sti.
Finally up on my feet, and working on 2 cars.
Old 05-07-2007, 12:35 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Clutch?
I would suggest an ACT 2100 with a sprung 6 puck.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-16-2007, 09:49 PM
Re: Clutch?
thanks a bunch the stage 2 by act looks like a good choice i really appreciate it. thanks again and yes i know i probably post ?'s that have already been posted i am just really anal when it comes to my eclipse, but arent we all?
