Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 10-19-2002, 10:49 AM
beau beau is offline
bmw sunroof drains
I have water leaking into a BMW 528i that I have determined is being caused by malfunctioning sunroof drain (probably clogged). Can anyone tell me how many drains there are? I see "front" drains that seem to drain forward. Are there any drains that drain to back of car?
Old 12-08-2002, 06:41 PM
rachel3790 rachel3790 is offline
Unhappy sunroof drains
My BMW 528I has the same trouble. One of the front drains is blocked. I think from someone driving on a curb. The bottom of it is bent in the way. I ran a metal wire down it and it doesn't help. I don't know what to tell you to do.. But there are 4 drains. They come out just behind the front tires and just before the back. If you look into the edge than runs in the sunroof you will see them. Fill them with water and you will see which one is clogged and where they come out. I havn't fixed it. I just left it and make sure or at least try to park on an incline or flat ground. If i do park on a decline i soak up the water before i drive out. hope that helps
