Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 05-06-2007, 12:13 PM
procrstinator procrstinator is offline
Headlight Adjustment
I HAVE A 2006 LS SEDAN .I BOUGHT IT NEW USED WITH 3000 MILES ON IT .THE FIRST NIGHT I NOTICED THAT THE LIGHTS WERENT ADJUSTED VERY WELL AS IT WAS DIFFICULT TO SEE TO FAR AHEAD ,UNLESS I USED THE HIGH BEAMS.I WAS GOING TO ADJUST THEM AND SURPRISE I COULDNT REALLY TELL WHAT KIND OF TOOL YOU NEED TO GO DOWN INTO THE ADJUSTING HOLE SO I LOOKED IN THE MANUAL TO FIND OUT THAT ..QUOTE>>>>"THE HEADLAMPS ARE FACTORY SET AND SHOULD NOT NEED ADJUSTING UNLESS THE CAR HAS BEEN IN A ACCIDENT .IF LIGHTS NEED ADJUSTING TAKE IT TO YOUR DEALER SERVICE DEPTMENT ! WHAT THE ? ..SO NOW IM WONDERING IF MAYBE IT WAS IN A ACCIDENT ? AND THAT WOULD ANSWER MY QUESTION AS TO WHY WAS IT BEING SOLD WITH 3000 MILES ON IT ? ANYWAY THATS RIDICULOUS THAT ONLY A DEALER CAN ADJUST YOUR HEADLAMPS !!!!!
Old 05-09-2007, 02:27 PM
mikedudley17's Avatar
mikedudley17 mikedudley17 is offline
Send a message via Yahoo to mikedudley17
Re: Headlight Adjustment
i have an idea. when you pop the hood you should notice that there are 3 bolts holding the headlight down. but you can maybe raise the beams slightly by adding washers to the bolts. this will raise the whole light up and out slightly depending on how many you use. thats what i had to do to mine after i hit a deer and the heaslight was forced down. i bent the shit back but i noticed it was still off a bit and i used washers to readjust the light and now you cant really tell.
damn aveos!!!
Old 05-18-2007, 05:18 PM
I Dont Want To Have To Rig It .its Under Warranty So Ill Take It In Thanks Tho
