Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-05-2007, 10:03 PM
jdsatyr jdsatyr is offline
Send a message via AIM to jdsatyr Send a message via Yahoo to jdsatyr
98 camero with brake light problem
I have a 98 camaro that the brake lights do not work on, the third (center spoiler) light does work when the pedal is depressed. I have checked the fuses, all the other lights (turn, parking, flashers and marker) work, we have replaced the brake switch at the brake pedal with no change. any ideas or suggestions appreciated
thanks
Jeff
Old 05-05-2007, 11:02 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: 98 camero with brake light problem
you checked the bulb fluid right?
jk. but seriously, you checked the bulb? if the 3rd light goes on that means the switch is ok. its prolly the wiring somewhere along there that got chewed up or fried. just check for +12v when the pedal is depressed on the brake light bulb line. if you got nothing, its your wiring
i hope you have a dmm..makes life easier. if you CAN, check continuity between the line + a chassis ground. if you DONT have it...guarenteed problem = wiring.. it probably means a rat or something chewed through your lines.
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
