Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 05-05-2007, 07:47 PM
mrmajestyk46 mrmajestyk46 is offline
86 Olds Regency
I own a 1986 Olds Regency with the 3.8 V-6. The car was sitting over the winter, about 8 months. Anyway, the engine idles at about 1500-2000 RPM, all the time, hot or cold, don't matter. I unplugged the IAC valve and plugged it back in with no change in idle speed. There is no "check Engine" light on. I don't see any vacuum leaks. Could the IAC valve be bad? Thank you for yuor help.
Old 05-06-2007, 08:47 AM
maxwedge maxwedge is offline
A990 racer
Re: 86 Olds Regency
Welcome to AF. Yes, take it out clean the carbon off, do the same to the throttle body.
Old 05-06-2007, 11:26 AM
Re: 86 Olds Regency
Thank you max, I'll give that a try.
Old 05-09-2007, 06:37 AM
Re: 86 Olds Regency
I put a new IAC valve in and cleaned the throttle body, still idles way high. I sprayed carb cleaner around the intake, etc., checked all the vacuum lines, did'nt find anything. I also turned the idle screw out, which still did not help. Anything else that would cause this?
Old 05-09-2007, 03:09 PM
A990 racer
Re: 86 Olds Regency
Yes a bad tps sensor, with a scanner you should have about .50 volts at idle, base idle screw back where it belongs.
