Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-05-2007, 05:34 PM
hahapopcorn hahapopcorn is offline
battery or electrical problem? -_-;;
I was fixing my subs and accidently dropped one side of the terminals connected to the battery (red side) for the sub onto a metal piece on my car and i hear a loud *pack* sound. after that had happened i started up the car and put down the e-brake the battery light, e-brake light and a weird orange yellow light above the ABS light (looks like a cage thing?) came on for about 5 seconds then turned off and as i was driving every time press down the clutch the rpm would drop near 0 as if it was about to die, i stalled once while i was trying to change gears =( When i am in neutural and just sittin in a parking lot it seems to be fine but i looked under the hood when i got home and there was a decent amount of acid built up around the red part of the battery terminal thing. do i need a new battery or did i mess up something with the electrical stuff? thank you for reading this. i'm a car noob haha
Old 05-05-2007, 05:39 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: battery or electrical problem? -_-;;
Try disconnecting the battery and cleaning up the posts and connections.
95 Talon TSI AWD
97 Eclipse GST
Old 05-05-2007, 07:45 PM
tried cleaning them off. i tried starting it again and when i started it there was this loud grinding noise and when i let off the clutch it goes away. and i noticed when its in neutural the idle is normal but when i get it into gear and start moving and press down the clutch the rpm shoots down like its about to die. i think it might have something to do with the clutch but after starting and re-starting the car it died completely and had to jump start it.
Old 05-07-2007, 04:52 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Ruined a many a batteries in such a manner , as for noise.. probably because the car is running irregular due to voltage issues , it kind messes with the clutch and tranny and makes marble like sounds.
I would take my battery to get tested , if bad - > Get another battery and double check all your fuses.
2004 Mazda 6i
1997 Tahoe
Old 05-08-2007, 11:17 AM
solar-eclipse solar-eclipse is offline
from the looks of it, your battery has been damaged, you can test it, once your moving your battery is using more power thats why your losing power and stalling out, either get it tested to see if thats the problem, or buy a new battery.
New out the box
1996 eagle talon tsi awd 78 MILES.... ON THE BODY!!
redemtion is a must.
Rip; 2005 subaru wrx sti.
Finally up on my feet, and working on 2 cars.
