Old 05-05-2007, 04:12 PM
90 T/A 90 T/A is offline
Several little problems
When my eq is on, the speakers whine with the motor... and when I click my eq on the subs thump... I hooked my subs through the eq... good or bad? should I have hooked it up through the cd player..?
Old 05-05-2007, 10:39 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Several little problems
problem #1 ... you're EQ is picking up noise from somewhere, or the RCA wires that go to it
problem #2 ... some processors have turn-on/off thump, some don't
problem #3 ... if the bass speakers are not connected thru the EQ, then the EQ will not be able to adjust them.
Old 05-07-2007, 11:47 AM
alright.. I think that my alternator and my eq are picking up the signals... so wat do i do about that..? its not really a hum... its like a real high pitch squeal..
Old 05-07-2007, 05:53 PM
Audio Guy
where are the amp and eq mounted
Old 05-09-2007, 09:13 PM
the eq is mounted kinda under the dash... and the amp is mounted in the upright position on top of my box... why?
Old 05-09-2007, 10:17 PM
PlayStation3 PlayStation3 is offline
because if you mounted and the chassis of the amp made contact with the negative ground it would pick up the noise.
Old 05-10-2007, 06:42 PM
Audio Guy
also could be the RCA run between the EQ and the amp
Old 05-11-2007, 09:23 AM
NotoriouslyLoud NotoriouslyLoud is offline
also make sure that your rca's and your power wire are not ran by each other... this can cause engine noise too.
Big D
founder of
Team Notoriously Loud Mafia
1 fi audio 18 btl fully loaded
1 soundstream xxx-6500
1 AVH-P5700DVD
2 G34 Yellow top
250 amp HO alt
bassrace 139.9 all day baby
Old 05-11-2007, 09:51 PM
Audio Guy
some myths never die
Old 05-11-2007, 11:26 PM
very true and my set up is truth of that.i got rca twisted twice around my power wire and i get no noise what so ever. ( i wanted to prove a point to a freind)
Old 05-12-2007, 08:18 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
If its a cheap brand eq it may not be filtered very well.
Old 05-12-2007, 10:34 AM
Audio Guy
I was gonna do that too, but I couoldn't easily get the RCA wires thru the drivers kick pod .... and they were gonna be too short.
Old 05-12-2007, 12:34 PM
i should post some pics of it, it's funny cause every one that is jealus is like he probelly gets bad noises coming out from it.
