Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-04-2007, 11:51 PM
SteveCooke101 SteveCooke101 is offline
1996 Dodge ram steering box
the steering box in my 1996 dodge ram is on its way out. very unstable and alot of clunking noises coming from the front. Is this a difficult job to do? what does it consist of? Is it possible to rebuild the one i have or would it be easier to by one that has already been rebuilt? Any Info would be greatly appreciated! thanks!
Steve
Old 05-09-2007, 11:19 PM
Taylor44 Taylor44 is offline
Re: 1996 Dodge ram steering box
Get some Lucas Oil Power Steering Stop Leak and try that first... it does wonders
Old 07-11-2007, 01:16 AM
MRDANGERUS MRDANGERUS is offline
Box weighs 31lbs, better get some helper. Check your steering links ball joints. Get under and ask ur kid to wiggle the steering wheel back and forth. You'll see/hear where the problem is.
Also, check Steering box Pitman arm shaft for any axial play.Should have no wobble at all. Should have 0 play. If it does-replace the box ( 3 bolts, 2 fittings and steering shaft bolt. Buy a rebuilt unit from Carsteering.com or discountsteering.com for $190 (free shipping). Get yourself a good heavy duty Pitman arm puller, braker bar, flare wrenches and get to work.
