exhaust ?
so i just bought an ac autotechnic muffler 5" for my 2000 eclipse gt which i do plan to do alot of future mods to such as a ripps supercharger most likely ...BUT was that a good buy? should i have bought used or stuck w/ stock or what? ne other sips wuld b appreciated
Re: exhaust ?
nothing is wrong with a muffler, as it is the most cost effective exhaust upgrade.
i just don't know what to say because it sounds like you bought a fart can, and it will need replaced when you get an SDS
![]() Don't act like you don't love it.
503/2000 |
Re: exhaust ?
well, technically if you plan on going SDS then you NEED a new set of tubular headers, shorties or long tube. I would say probably just go with some shorties because you can make up the extra power you would have gained from long tubes from boost (plus if you are boosting 6-8 pounds you wont notice the extra 5-10hp long tubes would give you versus the shorties). The fart can must go regardless if you go SDS or not...cat back systems with a decent tone are good, but strapping a muffler with a 30" tip on it is worse than insest (and yes the 30" is sarcasm...but its the simple fact that putting a Folgers Coffee can on your car doesnt make it cool in the slightest).
Other tips would be the obvious. Clutch and flywheel, LSD, motor mounts, short throw shifter and bushings, brakes (a must if you add power) and stainless lines, suspension, bigger tires (if you wanna go fast I wouldnt go more than 17" wheels because of the weight, but get fatter tires like a 235/245 or something, unless you go BBS or something lightweight), and if you wipe your ass with $100 bills then get a built bottom end for lower compression and more boost.
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
Re: exhaust ?
3'' is plenty big, even for turbo boost pressures.
Re: exhaust ?
If your happy with the sound then I would say it was a good buy....unless it sounds like these damn Honda's I'm surrounded by everyday I drive
.I personally would have recommended a good cat-back system but they can be on the pricey side. You will also want to get rid of that 2 1/4 in. piping if you go SDS on top of the other things that where mention. If you want to look into some cat-back systems I would recommend Invidia if your going SDS and the Greddy EvoII if your not going SDS.
North Star White 2000 Eclipse GT 5 Speed. Mods-Greddy EvoII Exhaust System,Injen Cold Air Intake,Megan Racing Short Shifter,ES Shifter Bushings,Greddy Counter Weighted Shift Knob, Fidanza Lightweight Flywheel, Prothane Motor and Trans Mounts,Clear Corner Lights,APC Euro Tail Lights,Mio C520 GPS,Passport X50 Radar Detector,Sony Xplode HU. |
Re: exhaust ?
Is this one of the ones you bought?
If so it's a 4" tip thats 5" long. Mesured from the end of tip to can. Looks like either a 2.5" or 3" inlet. This alone on stock piping would sound nice. Wont have that fartcan sound. By the looks of it, I'd say nice find. javascript:Popup('RTT500L') javascript:Popup('RTT600L') |
