Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 05-04-2007, 03:54 PM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Tachometer Failure
On our 1993 Trans Sport, the tachometer went from intermitttantly failing, to rarely ever moving. Once in a very long while it will remind us that it once worked and then nothing again. To begin with, what are the common things I can look for that don't require a bunch of equipment? What are the most common reasons for failure?
Old 05-04-2007, 06:15 PM
LMP's Avatar
LMP LMP is offline
Re: Tachometer Failure
Which engine is it? Tach signal is taken differently on 3.1 and 3.8.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 05-04-2007, 06:38 PM
tinkering's Avatar
In the 200 Club
Sorry about that. It is the 3.8 engine.
Old 05-04-2007, 07:26 PM
LMP's Avatar
LMP LMP is offline
3.8 OK..so follow the Vin L path on this diagram
www.avigex.ca/xport/instrumentpanel.jpg
THere is nothing but a single wire between the ignition module and the tach...so most probable the problem is in the instrument cluster, connectors or the tach movement itself. FIve or six screws will remove dash upper cover; then light and wiper switch, and you have easy access to pull out the instrument cluster to check connectors .
Here is the procedure form GM shop manual:
Tach inoperative:
Disconnect instrument cluster connector
ENgine running
Use a digital volt meter: measure voltage at insteument cluster connentor terminal D7 to ground.
Voltage should read approx. 1.5 V t idle
Does voltage increase as engine speed increases?
Yes: replace Tach
No: Check for open contact i connector 121; if OK replace Electronic Ignition Module
Comment: If car runs normally, I would not change the Ignition Module just for the tach.....
Old 05-04-2007, 08:51 PM
tinkering's Avatar
In the 200 Club
Is that single wire traceable? I agree. Why mess with the module if the thing is running good? Maybe I could pull another tach from the wreckers next time I'm there. I could pull the dash and try it in there while it is apart; I could do the voltmeter check too. Thansk a bunch
Old 07-11-2022, 11:48 AM
tinkering's Avatar
In the 200 Club
This is a very late follow up this thread. The problem was indeed the ignition module. I replaced it with a wreckers unit and voila. The tach signal is controlled by the ignition module. Didn't have to pull he dash apart this time.
Thanks
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
