Old 05-04-2007, 12:20 PM
Zlaja_'s Avatar
Zlaja_ Zlaja_ is offline
Send a message via MSN to Zlaja_
Finished - Supra MKIV
Stock, built it curbside because the engine was needed for something else
All the flaws are nearly invisible in real life except the paint misses at the window edges.
C&C please, but most important- be brutally honest!
Old 05-04-2007, 05:15 PM
digitalbanzai's Avatar
digitalbanzai digitalbanzai is offline
Re: Finished - Supra MKIV
Paint looks really smooth as does the CF Decal, but it's in bad need of window trim.
Old 05-04-2007, 08:43 PM
rod_k2's Avatar
rod_k2 rod_k2 is offline
Send a message via MSN to rod_k2
Honest? Ok.
Looks great! But it would be even better a bit lower...It sits a little high,or is just the pics??
What have you used to glue the front-back rear lights?
"Oh noez,it has more stickers than me! And a wing too!
Old 05-04-2007, 09:31 PM
NOMADGAMER NOMADGAMER is offline
paint looks excellent!
needs: rear wiper, black paint around the inside rim of the headlight lenses, a tad lower ride height (even though they are 19" wheels), and use a lot less glue when you put the drivers mirror on, or maybe the paint is bad around the mirror base?
Old 05-04-2007, 11:11 PM
energon's Avatar
energon energon is offline
For the most part it looks great! I do agree with what everyone's said. Could use some more details (i.e. the insides of the front and rear lights, side markers, inside window trim, and interior), could probably use some lowering. The Paint and Carbon looks awesome!
click me ^
My Deviant Art
Old 05-05-2007, 04:17 AM
Zlaja_'s Avatar
Thanks everybody, i tried to paint the inside window trim but it was too har for me to try and mask off. The outside window trim got a tad f*cked up and the glue for the rear view mirrors isnt actually visible in real life :S
Regarding the ride height, i will keep it in mind for the next supra i'm making. I've heard from several dudes that the supra sits very high even at stock wheels/brakes.
Old 05-05-2007, 04:38 AM
R34_4_life's Avatar
R34_4_life R34_4_life is offline
R34 GTR wheels on a Supra!!?? *inhales* *exhales* Not my kinda style but hey....
That's thirty minutes away!!!
I'll be there in ten!!!!!!!!!!!!!!!
Old 05-05-2007, 04:57 AM
Zlaja_'s Avatar
Hey man, there are thousands and thousands of wheels that look like the R34 ones (and i guess nissan didn't come up with that design first in the world). Just imagine that they aren't nissan wheels and there you go
Peace
Old 05-05-2007, 02:36 PM
energon's Avatar
I thought this kit came with pre-cut masks for doing the inside window trim.
click me ^
My Deviant Art
Old 05-05-2007, 02:58 PM
voyageur voyageur is offline
Honest....allright.
Like the other guys said the paint is good. I don't really like the carbon hood, but it's done well. Wheels are totally your choice....I have put them on an NSX that is posted here in AF somewhere and must say they look good on a lot of cars.
Headlights are really bad, just take a look at a pic of the real car (or the instructions for that matter) and you are good to go. Same for the rears...and don't forget to paint the edge black on all of them ;-)
Panel lines look good, but could be a tad thinner in some places. Window trim is missing as mentioned before.
Either paint the sidemarker or remove it...
OK, enough said. Don't take it too hard...with patience and practice you can become a really good modeller. Keep it up!
Old 05-09-2007, 07:22 AM
Risko's Avatar
Risko Risko is offline
Nice CF and paint!
For the inner window mask, I use a 1mm or less tape and then bigger to the center, so you can follow the lines better with very thin tape. Then look from outside if the tape has no bubbles where the paint could run into. If you see some, you can press them away with a tooth pick.
Old 05-10-2007, 12:27 PM
Looks similar to one of mine. =D
Mine came out a little lower... but it's stock height also:
http://www.automotiveforums.com/scal...tle/supra.html
AF MODELING FAQ
"Oh what a feeling.- Toyota
