Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 05-04-2007, 10:34 AM
obryan71 obryan71 is offline
2002 misfire
My sister has a 2002 neon with 29000 miles. Car was missing bad on acceleration. Changed the plugs. Car ran fine for a few days now its acting the same way it did before the new plugs. Checked the the wires and coil pack for visual signs of defects and none were evident. Any suggestions?
Old 05-04-2007, 10:54 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 2002 misfire
Is the CEL lit?
2003 Dodge SRT-4
Old 05-05-2007, 08:45 AM
Re: 2002 misfire
Im not sure what the CEL is. But if you are referring to service engine lights none are on.
Old 05-05-2007, 08:48 AM
Re: 2002 misfire
Check Engine Light.
What plugs did you put in there? Misfires could be alot of things; plugs, wires, coil pack, fuel injectors, fuel rail clogged and so on. How many miles on the spark plug wires?
2003 Dodge SRT-4
Old 05-05-2007, 11:05 AM
Re: 2002 misfire
Replaced with champions plugs gapped at .35. I took Bosch Platnum out that were about 6 months old. The wires are original the car has 29000 miles on it. They are pretty heavy wires. Always used same BP gas with the occasional bottle of fuel injection cleaner. I guess we could try replacing the wires. Should I also replace the plugs again?
Old 05-05-2007, 12:45 PM
Re: 2002 misfire
Pull the plugs and take a look at them.
2003 Dodge SRT-4
Old 05-09-2007, 04:19 PM
Re: 2002 misfire
Replaced wires today. Car is running much better. Thank you. I just thought that those stock wires lasted longer than 30,000. Plugs looked ok, what is a good plug to run in this vehicle.
Old 05-09-2007, 04:23 PM
Re: 2002 misfire
30,000 miles sounds about right to me. Run the stock plugs in the neon. Stay away from platinum and split-fire plugs. No benefit over stock on the neon.
2003 Dodge SRT-4
