Old 05-04-2007, 07:49 AM
dgwiii dgwiii is offline
Question Daytime Running Lamps Not working
I have a 1996 silverado and my DRL just quit working. The green light on the dash is still on indicating that they are working but they arent. headlamps work fine when turned on, i have looked for fuses and relays but they seem to be good. Any suggestions?
Old 05-04-2007, 03:25 PM
silveradofirerescu silveradofirerescu is offline
Re: Daytime Running Lamps Not working
i'm convinced that the drl lights suck. try replacing the bulbs. they are weird cause they will look like good bulbs but not work. also, for the lights to work the truck has to be in the run position in drive. hope this helps, i have the same problem right now.
Old 05-04-2007, 07:32 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Actually in pre-'99 and up body style trucks, the lights come on when you turn the car on. At least they do on my parents Tahoe.
*Under Construction - New sig to debut*
Old 05-05-2007, 10:50 AM
777stickman 777stickman is offline
In your '96 the low beam lamps and DRL's are the same. The DRL relay is in the convenience center(behind the park brake) bottom center position. Pull it out and check for 12 volts at the upper right slot. There should be 12 volts there at all times from the DRL/FOG fuse. If power is there change the relay. If not change the DRL diode (203) located in the I/P wiring harness right side of steering column support (2 wires, yellow & orange). Let us know what you find............Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
