Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 05-03-2007, 10:10 PM
netshop netshop is offline
98 Avalon - Check Engine ON code P1780
Hi,
I need some help. Recently I bought a 98 Toyota Avalon (65K miles). Check engine light is ON. It was due to Oxygen sensor. So i fixed it for $400 from a mechanic. Immediate next day, Check Engine Light came ON again. This time it is code P1780 - which refers to Park/Neutral Position switch malfunction.
Now I want to know, how much this will cost now? what will happen if I don't fix it. While changing gears during starting, I could feel some jerk/jump. But it is smooth when driving at speeds. Any sugestions/help??? Thanks
Old 05-04-2007, 11:07 AM
csaxon csaxon is offline
Re: 98 Avalon - Check Engine ON code P1780
Possibly loose or out of adjustment or defective. The cable to it also stretches over time and may need tightening.
Unfortunately, it may have been the cause of your o2 sensor code, because it signals the o2 sensors when the shift lever is in position D. If not adjusted properly then you may not be able to start your car without fishing around with the gear shift. It also affects your backup lights. The site below has info on it. It's the same as yours.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/13/f4/46/0900823d8013f446.jsp#hd1-1-1#hd1-1-1
It worked fine until I fixed it!
Old 05-06-2007, 10:06 PM
Thank you so much csaxon. I am going to talk to mechanic with whatever inputs you had given. hopefully it does not cost much. Thanks again.
Thanks
Sam
