Old 05-03-2007, 08:36 PM
Mod_12 Mod_12 is offline
A bunch of Silverado ????'s
My 2000 [COLOR=green ! important][COLOR=green ! important]Silverado[/color][/color] 1500 5.3 4x4 will skip or shudder when I'm pulling a trailer or just going through hilly country. When towing I use the tow/haul feature in drive not o\d and usually set the cruise at 70 mph. If I encounter a hill where my speed drops back to around 68mph the skip/shudder starts. When the transmission drops to a lower gear the skip/shudder quits or is not noticeable. It does it in the mornings on level roads in o\d but doesnt do it drive. The other day when i was at a light and went to go it felt like the tranny slipped then it banged into gear. I have been told it may be a senor or something for the shifting problem.
Also when climbing a tiny hill on cruise control my speed drops 1 mph it will then kick down to passing gear and sometimes it wont. I thought it was around 5mph it should downshift but not to passing gear. Sometimes I almost have to put it to the floor to get it to downshift for some power to climb the hill. I am towing a small 10ft open trailer not a big thing at all. I was told to check the cables for slack and they are good in the regard. Thanks for any help you may have.
Old 05-03-2007, 08:43 PM
Re: A bunch of Silverado ????'s
also forgot to put that tranny fuid is full and it had a complete tranny sevice at 100,000.
Old 05-05-2007, 10:20 AM
daman daman is offline
When was the last time it seen new plugs wires cap rotor??
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 05-05-2007, 01:37 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
99-up v8 Silverados do not have a cap or rotor.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-05-2007, 01:55 PM
Woops!!! missed that, yes i know..lol
Old 05-08-2007, 07:06 PM
ripptide56 ripptide56 is offline
I had the same problem with my 99 with a 5.3. I had the injectors cleaned and the problem went away.
Old 05-11-2007, 08:07 PM
Well, I think it was the EGR valve that may have been causing the problem. My check engine light came on today and it gave the code for a bad EGR. Replaced it and now it climbs hill and all without kicking down on cruise. Must have been loosing power when it was starting to go bad. Now if i can get the shifting issue resolved.
