Old 05-03-2007, 09:35 PM
chadis's Avatar
chadis chadis is offline
Thumbs down Need torques specs ASAP!!
Need torques specs for my rocker arms not the studs the arms themself .. for a 1987 Camaro 355 v8 cast heads i cant seem to find the damn specs i need any help would be great
Thanx
Old 05-03-2007, 11:10 PM
Morley Morley is offline
Re: Need help ASAP!!
Thanx
There is no torque on the rocker nuts. The valve train is adjustable and those nuts are the adjusters. Do a Google search on setting valve lash on smallblock chevy. You'll find a wealth of atricles on how to od it.
Old 05-03-2007, 11:26 PM
chadis's Avatar
WIth Hydraulic lifters i thought they were self adjusting
Old 05-04-2007, 12:11 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
no, they usualy dont self adjust you have to set the valves, typically to adjust them, tighten nut until until drag on pushrod(while turning the pushrd itself) and then i usually go 3/4 of a turn more
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-04-2007, 11:18 AM
Not self adjusting, they use hydraulic dampening to keep them quiet and eliminate the clearance associated with solid lifters and overhead cams. You need to set the preload on them and that is what the adjuster nuts are for.
Old 05-04-2007, 01:58 PM
MrPbody MrPbody is offline
AF -Advisor
For clarity, the '94-newer small blocks had the positive stop with no adjustments. Ford ("big blocks" and mid-'69-newer small blocks), Pontiac, Olds, Buick, Caddy, Dodge, AMC all had positive stop-type (valve stem height is critical) non-adjustable lifters. Chevy was odd man out in this matter.
Jim
Old 05-04-2007, 06:47 PM
chadis's Avatar
Thanxs i got them figured out but now i get the hole thing together and only seems to fire on one bank like wht the hell ???
Old 05-04-2007, 10:33 PM
83T/A98Blazer 83T/A98Blazer is offline
Did you adjust all the valves at once? On a Chevy V8, you adjust half of the valves in the #1 firing position and the other half at the #6 firing position. Here is an Autozone page that lists which valves to adjust at each position. http://www1.autozone.com/az/cds/en_u...rInfoPages.htm
