Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 05-03-2007, 03:20 PM
Amechanic's Avatar
Amechanic Amechanic is offline
New car break-in
Hi all, I just brought a new 2007 Corolla. In the manual, it states for the first 1000 miles, do not drive for a long time/distance. My question is how long is too long.
Thanks in advance
Old 05-03-2007, 03:23 PM
klieu klieu is offline
Re: New car break-in
Thanks in advance
Like a long trip, 100+, go around the town
Old 05-05-2007, 11:28 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
An interesting article on breaking in 4-stroke engines from a very successful engine builder.
http://www.mototuneusa.com/break_in_secrets.htm
And one about breaking in Lycoming aircraft engines.
http://www.lycoming.com/support/tips...Operations.pdf
See the first page...
"A new, rebuilt or overhauled engine should receive the same start, warm-up and preflight checks as any other engine. There are some aircraft owners and pilots who would prefer to use low power settings for cruise during the break-in period. This is not recommended. A good break-in requires that the piston rings expand sufficiently to seat with the cylinder walls. This seating of the ring with the cylinder wall will only occur when pressures inside the cylinder are great enough to cause expansion of the piston rings. Pressures in the cylinder only become great enough for a good break-in when power settings above 65% are used.
Full power for takeoff and climb during the break-in period is not harmful; it is beneficial, although engine temperatures should be monitored closely to ensure that overheating does not occur. Cruise power settings above 65%, and preferably in the 70% to 75% of rated power range, should be used to achieve a good engine break-in.
Remember that if the new or rebuilt engine is normally aspirated (non-turbocharged), it will be necessary to cruise at lower altitudes to obtain the required cruise power levels. Density altitudes in excess of 8000 feet (5000 feet is recommended) will not allow the engine to develop sufficient cruise power for a good break-in.
For those who still think that running the engine hard during break-in falls into the category of cruel and unusual punishment, there is one more argument for high power settings during engine break-in. The use of low power se
ttings does not expand the piston rings enough, and a film of oil is left on the cylinder walls. The high temperatures in the combustion chamber will oxidize this oil film so that it creates a condition commonly known as glazing of the cylinder walls. When this happens, the ring break-in process stops, and excessive oil consumption frequently occurs. The bad news is that extensive glazing can only be corrected by removing the cylinders and rehoning the walls. This is expensive, and it is an expense that can be avoided by proper break-in procedures.
To summarize, there are just a few items to remember about engine break-in:
1. If a preservative oil has been added by the aircraft manufacturer, drain it no later than the first 25 hours of operation;
2. Follow the engine manufacturer’s recommendation regarding the oil to be used for break-in and the period between changes;
3. Run the engine at high cruise power levels for best piston ring/cylinder wall mating;
4. Continue break-in operation for 50 hours or until oil consumption stabilizes. These simple procedures should eliminate the possibility of cyli
nder wall glazing and should prepare the engine for a long and satisfactory service life."
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
