Old 05-03-2007, 02:51 PM
penski penski is offline
2002 Olds Intrigue
The mode doors on the heater change from defrost to dash vents fine, but when turned to heater on the floor the heater blows moderately but the dash vents continue to bleed a fair amount, has anyone encountered this ? If you shut the vents off at the vents themselves then the airflow to the floor strengthens slightly. The car has the dual zone climate control and auto air. Any help would be appreciated.
Thanks Penski
Old 05-04-2007, 02:50 PM
dtownfb dtownfb is offline
Re: 2002 Olds Intrigue
I pretty much keep mine in auto mode except for the occasional need for full blast defrost mode. I'll check it on the way home tonight.
Old 05-05-2007, 07:30 AM
Jimmy Olsen Jimmy Olsen is offline
Thanks Penski
I suspect that what you experience is normal. Probably has to do with reducing back pressure on the fan, i.e., the system can't channel all of its output to the floor vents.
