Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 05-03-2007, 02:42 PM
jacksongriff jacksongriff is offline
Tach, speedometer, fuel, temp gauges
i just got new gauges, the tach was really hard to install and i dont know how to get the other ones off. so can some one tell me how to get them off and put the new ones on?
Old 05-07-2007, 08:17 PM
tkd2000 tkd2000 is offline
Re: Tach, speedometer, fuel, temp gauges
I assume you want to remove/swap the speedometer, fuel, temperature gauges of your instrument cluster. Go to this site, the instructions are very clear (and easy):
http://www.honda-tech.com/zeropost?cmd=tshow&id=1964566
Good luck
Old 05-07-2007, 11:33 PM
no i bought just new gauges, not the whole cluster, i screwed up the tach and had to buy a whole new cluster off ebay, i was told that i need to remove the old gauges without taking off the needles and maneuver the new indiglo ones over the needles some how..see what im saying..the thing you sent looks like taking the whole cluster out and putting a new one in. but thanks tho
Old 05-08-2007, 06:41 AM
Go to honda-tech.com, do a search on cluster/gauge or create a thread at the appropriate forum and explain your situation/problem. I am sure there are a lot qualified persons with good knowledges to help you. Good luck
Old 05-09-2007, 10:43 AM
xplodn xplodn is offline
if your just swapping out the clusters, then take out the trim screws, then take out the cluster screws, then unplug the cluster, its like 5 mins or less, then reverse to put it in, its so easy even a cave man can do it. all you even need is a phillips screw driver.
