I have a 91 buick that when in park it idles poorly. But going down the road seems fine. I put new plugs and wires in it and a new air cleaner . What else can I check?
Re: 91 lasebre idling poorly
Check all the hoses and tubing connections, especially those in and around the carburetor. On a car that old, if they've never been changed, I'd be about willing to bet one is cracked and leaking somewhere. Sometimes they're not that easy to find just by looking at 'em and feeling of 'em; you have to actually take the tubing off the fitting. In most cases, when you do that, you need to cut the tubing back a half-inch or so before putting it back on the fitting. And then sometimes you need to just go ahead and replace the whole piece of tubing.
Change your fuel filter and PCV valve if you haven't already done so in a while. Are you getting a check engine light? BTW, the '91 is fuel injected and does not have a carb
![]() http://www.cardomain.com/ride/2653398 1992 Buick Park Avenue (Daily driver) 2001 Saturn SL1 (gas saver)
I know that! God, I hate getting old! Thanks for the correction. ![]() To the OP: do what I said, but scratch the word carb. |
Just thought I would throw this in. I have the same car, had the same symptom. Did the usual, replaced plugs, air filter, pcv valve. No check engine light ever showed face. Also had alternator issue so replaced that and the battery too. Still, rough idle when stopped or in park.
After living with it for about 5 months, she died while driving down the road. Just simply cut right out and would not restart. Coasted into a Sonic Drive-In. Bit of a struggle with no power steering or power brakes.. ![]() Ordered the $35.00 combo. $5 for the meal and $30 for the tow. Fuel pump. After driving it out of the service garage, the car had more pep than ever before! Idling perfectly now and has been for just under a year now. My guess is that the whole time it was the fuel pump living it's final days until it quit alltogether. Of course the fuel filter gets replaced too, so that may have played a role. Nonetheless, the car runs like it did back in '91 and could not be happier. Good luck |
