Old 05-03-2007, 12:53 PM
sivad sivad is offline
accessing rear door handle in 2000 lesabre
am needing information in how to remove door handle from the rear door of a 2000 lesabre....after the door panel is off of course.
thanks in advance
Old 05-14-2007, 03:59 PM
rustbucket rustbucket is offline
Re: accessing rear door handle in 2000 lesabre
I replaced the front door lock actuator on my '99. I had to take out the whole internal workings.. -- lock actuator, window actuator, door handle- everything. it all came out.. It is a 1999, here are my notes, for what its worth. A 2000 may be similar.
Take off inner door panel
Un hook all cable hold downs in metal inner panel
Remove 5 Torx and take off speaker
Lower window to about half and remove 2 nuts attaching window to lifter base channel
From inside push window up and tape in closed position
Remove 4 torx screws from end of door
Take off all nuts holding inner panel to door
Use on extension to go through inner door holes and remove 2 10mm bolts to door handle
Slide c clip off back of key lock
On outside of door pull door handle rod up and unclip plastic clip and slide handle off rod
On outside of door pull key lock rod up and unclip plastic clip and slide key off rod
Remove inner panel with rods and actuator/door latch
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
Old 05-15-2007, 10:38 PM
Thanks rustbucket for your reply......will print this off and hopefully when time permits we can get this repaired ourselves. Thanks again!!!
sivad
